GRAPE-DRANK
I have had my motor completely broken down. The cam timing gear, camshaft, and crankshaft are all a no-go. I need a usable cam and crank. The machine shop said I could use the crank timing gear if I wanted. They said that it is still serviceable, but that it might be a bit noisy mated up to a new camshaft timing gear.
Know where I can find a good Crank and Camshaft?
Here's what I got so far:
Super A cylinder head - Good part, machine shop will use.
Block out of a 130 - Good block, Good bearing caps, no cracks machine shop will use.
Super A piston rods - No damage, inspected machine shop will use.
