Super A Hydraulic Oil Question
nh8260
Is the Hy-Tran the correct oil to use in my touch control hydraulic system on my super a? Also, i was thinking of changing the tranny oil in it as well, what is the capacity of it? What is the best weight of oil to use for it? And finally, i saw there are two plugs, one right near the dash and the other behind the gear shifter, which do i use to add the new oil back in?
Sounds like you need to invest in an owners manual before you need more answers. Hy-Tran wast out when the SA was new. Tranny uses 90wt. Doesent it make sense to go by the manual instead of advise from someone you dont know.There are those out there will tell you to use Hy-Tran in the tranny.
