Trouble Shoot
I have a 706 Farmall, I noticed tonight that there is a slight noise under the platform below the driver. The tractor takes off when you let the clutch out. But sometimes it hessitates and will start and stop then take off. It is just like the clutch is being engaged and disengaged. It seems to do this with the T/A forward or back? I just installed a new clutch a few months ago, but it has very little use. I also noticed that when on a slight incline and the clutch pushed in it did not roll back. I put it in neutral and it rolled back. Any Thoughts are appreciated. Is the clutch out of adjustment? Thanks
If you put in a new clutch you need to adjust the trans break on the right side of the tractor the service manual outlines how to do it. The noise might be the trans break draging inside.
