drawbar EXTENSION,
tn terry t
if you dont mind would someone with a farmall h measure the drawbar extension if you have one, the part number is 66426d i want to be able to pull my ole 472 haybine if the need arises but the draw bar is too short
I made one out of a old drawbar from a ford tractor, bolts on my existing drawbar, I think I made it 6 inches long for my baler, have to take it off for the haybine though....Jim
I used to see several different lengths some longer
than others. I have one somewhere that fairly long.
I'll see if I can find it and if there is a number
on it. If you look in your haybine manual it will
tell you how far back from the end of the PTO you
need to be.
IIRC, the standard distance from the tip of the PTO shaft to the center of the drawbar hole is 14".
(quoted from post at 05:27:09 05/21/11) IIRC, the standard distance from the tip of the PTO shaft to the center of the drawbar hole is 14".
That's our pulling clubs standard distance.
