SM water pump bearing spacer
Anonymous-0
Does anyone know the correct length dimension for the water pump bearing spacer for a C264. Rebuilt mine recently and pulley rotated easily before bearing nut was tightened. Believe my spacer is worn causing bearings to be preloaded.
Most likely you are feeling the resistance of the felt behind pulley, assuming you installed a new one. Pretty hard to apply a preload to a ball bearing set up like in there. I would try it without the felt to compare.
