wide front end
"Bone yards" are a good place to start. Also, this website is a good bet. I have bought 2 wide front ends off of this site. Problem is that you never know when they are going to come up.
The wide front and the tricycle front are easily swapped. However, if you are used to the tricycle front, the tricycle front is much more manuverable than the wide front axle. I personally would not recommend a wide front axle on a C because of the manuverability.
Harold H
(quoted from post at 07:54:22 04/30/11) hey i was wondering if there is any way to covert a narrow front end c to have a wide front end?
I have a Super C with wide front that i want to convert to a narrow. The wide is a little beat up but works just fine. If you wanted to set up some sort of swap we could make arrangements. I have been told that the C, Super C, B, and BN all use the same front end components.
