update on 806 brakes
Dave from MN
Frustrating. Ended up taking the brake valve off the 1206 and putting on the 806. 806 brakes still locked up at soon as tractor was started. Put 806 valve on 1206 and 1206 worked the same as before. SO, moving on to the "master control valve"? Have to be getting to much pressure to the brake valve right?? Has any one ever seen an instance where the "dump" line from the valve got plugged after the brake valve assy some where?
