Farmall front hubs
My Super M has a standard duty Swartz wide front that takes the original IH 3 bolt front hubs and open center wheels. After 30+ years using a Farmhand F 11 loader, I am starting to have a few rim problems. Is there an ordinary 6 bolt implement hub that will fit that spindle? If so, is it available through CIH or is there an after market source? What would the part number or model number be? Thank you,
Gene Popkes
(quoted from post at 06:47:22 04/25/11) My Super M has a standard duty Swartz wide front that takes the original IH 3 bolt front hubs and open center wheels. After 30+ years using a Farmhand F 11 loader, I am starting to have a few rim problems. Is there an ordinary 6 bolt implement hub that will fit that spindle? If so, is it available through CIH or is there an after market source? What would the part number or model number be? Thank you,
Gene Popkes
Sure, a 6 bolt hub is available to replace the standard cast hub, but then the spindles are going to be the weak point. Heavy duty spindles are available, but I'm not sure those will fit the standard duty front end. To do it right, install a brand new, heavy duty Schwartz wide front, and sell your old one. The old one should be worth roughly 1/2 to 2/3 the cost of the new one.
The cost of the parts needed to rebuild what you have now and turn it into a heavy duty model will be somewhere around 1/2 the cost of the complete heavy duty wide front.
