Removing Injection Pump from 1256
JWCarp
I just bought a 1256 that needs some work done on the injection pump. Reading the IT manual I have it says to take off the turbo and the exhaust manifold and then remove the pump with the lines on it. Does anyone have any shortcuts to removing the pump without taking the manifold off? Can I pull the manifold and the turbo together or do you have to take the turbo off the manifold like the manual says? Thanks for the help.
You have 2 take the manifold off cuz the fuel lines are behind it.You can take the manifold,turbo and exhaust elbow off together tho.
