300 hydralic system O rings
PaulGinMn
We have a 300 that there is alot of leaks on the hydralic system and want to replace the O-rings. Is there anything special to them or can we just buy a generic kits and size them up? Thanks Paul
When I re-did my first 300 I replaced all of them, I bought them all through Case-IH (cha-ching), I would purchase one of each size you will need and try to match them up with generic ones, BUT at least with buying them through the delaer you have the right size for the spools in the valves, the rest I am sure are a pretty standard size, and could be matched up. I decided I did not want to take it apart again so I got the right ones from the dealer to begin with. It certainly was a bit expensive, but when I was done I had no leaks, and everything worked like it should.
