F-20 Flywheel Ring Gear Needed.
I need a flywheel ring gear for a F-20 IHC tractor. Does anybody have one of these or know if it is the same as anything more common. Mine has sat for along time with big, nasty nest in the bottom of the bellhousing and about a third of the teeth are severly corroded. Welding them up and cutting them back seems like it would be a very tedious task. Thanks Jeff 308-940-0255
I think they used a ringgear from an M.Others on here will know for sure, but you might at least pop it off and compare or measure it and see if they are the same.
