Farmall H carb part
Anonymous-0
There is a jet broke off inside the bowl of my carb. I got it out and the threads look good. The problem is I can"t find one anywhere. I looked at the carb kits on here but not sure if they will come with it or if it will work. Any help would be appreciated. Thanks
Did you check with the dealer to see if it's still available? I worked on one for a friend a couple of years ago and someone else had been in there before me and there was a jet missing. That one WAS still available and the dealer had it in a couple of days.
I went to the dealer and the jet is $30. So I did some looking around and found a kit with one in it for $25, go figure. Thanks for the help.
