Farmall 300 Engine Trouble
I just want to start this off by saying engine trouble is not my
strong suit. I previously noticed that my Farmall 300 engine was
missing on one cylinder. I thought it may be just a stuck valve,
but it never cleared up. So I pulled the tappet cover, and noticed
one push-rod was not in the rocker anymore. There was an
issue that the top of the tightener had been slightly stripped, so
the jam nut could not be tightened. This problem was fixed with
a new tightener screw. However, when I was installing this I
noticed that the tightener screw had to tightened substantially
more than all the others. It almost seems that the push-rod is
not as long. I don"t know if something is going on down below
that is causing this? I switched push-rods with another valve and
this issue still persisted. If you could offer any suggestions, it
would be greatly appreciated. Thank you!
Is the cam lobe worn? Observe how far the problem valve moves compared to the others.
You can remove the cover located behind the distributor (magneto?) to look more closely at the lifters.
If you're planning on doing the work yourself you need a good service manual on the tractor. If it has a worn cam lobe that will involve a good bit of work just to remove the cam. Hal
Also check for bent or stuck valve. When closed tip of stem should be near the same height as others when closed. Also compare rocker arm to a good one.
I was able to take the side shield off today and found that my problem was a broken lifter. Pretty easy fix. Pulled the pan and pulled out the broken pieces as well. Have a new lifter on order. Thank you all for your help.
