D282 cracked sleeve pic
robgIN
I have read posts here about engines running fine good oil pressure then knocking badly and finding a pan full of chunks of metal that used to be a sleeve before the got pulled down into crankcase and destroyed by the crank. This is a before pic luckily. We tore it down for a valve issue and saw this. Would have been a lot worse pretty soon.
We have two 560's in the family but I haven't been into either one of them. I remember reading something here about a variation between earlier and later blocks and sleeve fitment. Apparently it's possible to put the wrong sleeve in.
Good catch!
Looks like you got there just in time. I wouldn't be too suprised to find that bore in the block to be on the loose side too. Probably either fall right out, or fight you all the way! Depends how much soot has been forced through the crack, I suppose.
The last few of these I have overhauled, I have used a sleeve retaining compound on, similar to loctite, and primer, that is made for this. Heat tolerant, and transfers heat also. One has logged over 3000 hours no problems so far. Be sure to get sleeve standout set evenly. I like to keep it to the low side of the spec. This can be tricky without the special tool.
Good luck!
