3 pt hitch won't raise..
dz4swamper
New User
I'm tearing down a friends IH 2050 series A tractor and his 3 pt hitch won't raise at all and he has no power steering and the PTO won't turn. Ive taken apart the MCV and found nothing obvious. There is a lot of water in the oil by the looks of it. It's really milky. Is there anywhere that I should be looking that you guys have found to be a problem? Any and all help is needed.
Thanks
Sean
Guess you checked the filter, sounds like flow control stuck, I have been throught this before and it can be fun on these tractors
Is the flow control in the MCV? Yes, Im replacing the filter. I took off the MCV and pump and tore it down as far as I could, no orings were knicked or broken.. But like I said there was some massive water intrusion since all the oil was milky..
