Rubber Lugs for F12 Steel Wheels
Anonymous-0
Where can I purchase rubber lugs for an Farmall F12. Was at a tractor show this weekend and saw a Rumley with 3 to 4 inch rubber lugs mounted on a steel wheel with spikes. There was nobody present to ask where I could find them.
I looked at Miller Tire website. They did not have the type of lugs I am talking about. The ones I saw are oval to retangular shaped. and mounted down the center. Miller Tires only have a banded type rib. Thanks anyway.
Brad,I own a few F12 that I wanted to leave the Steel wheels on but have rubber just for shows.Your right they dont make and you probally couldnt afford rubber lugs.I found that if you cut the center out of a 38 in tire it will fit tight around a F12 wheel,and carriage bolts will hold the tire in place
jimmy
Brad, unless miller stopped selling them! In my catalog it shows rubber coated lugs with bolt and nuts $10 each. That is the only one I have ever seen that is called a lug. oldiron29
You might try www.taubetool.com. They make a composite lug for steel wheels. you will need to go down to the fine red print at the bottom left of the page and click on Composite Materials.
(quoted from post at 16:44:29 03/21/11) You might try www.taubetool.com. They make a composite lug for steel wheels. you will need to go down to the fine red print at the bottom left of the page and click on Composite Materials.
Those look nice!
A few years back, somebody made the IHC type spade lugs in molded rubber of red, green, or orange but I can't find this sourse now. The Miller rubber lugs are flat bar type lugs and the taubetool are the one sided John Deere type spade lugs.
Harold H
