1466 remote hydraulic couplers wont let fluid pass through
ENT
New User
unhooked the hoses on my 1466's loader today and after I put them back on the loader wouldnt lift. It worked fine right before I disconnected them but now wont budge. I cracked the lines and there is pressure there but it wont flow through the remote, the remote is the lever type. I am baffled, what does that remote have in it that would not allow pressure through.
thanks for an help in advance
On Dad's 1066, you have to flip two little levers on the coupler block before you unhook the hoses, then flip them back after you reattach the hoses.
I think they are some sort of ball valve. The hydraulics won't work unless you flip the levers.
They point up and down when "closed" and point back when "open."
Take a look at the cam inside the lever coupler, often times they will shear the pin and be out of sync or another possibility is lever is twisted or bent.
