International 885 XL brakes
TIK531
New User
Does anyone wnat to talk me through whats involved with repairing the brakes onan IH 885. I have replaced the reservoir ounder the bonnet thinking that the sleeve slipping was the problem. I bled the brakes and all seemed well but in a few days I lost the brakes agian so assume oil is leaking at the caliper?? What next??
Just went through the exact same thing with my 885. Its pretty straight forward once you start. You have to pull the tire and wheel and the axle housing, Then the rest is self explanitory, (all for a $4.00 oring) good luck
I went through the same thing on my 885XL a few years ago too, and 1468 Chris is exactly right. You need to replace the o rings in the axle housings. I will see if I can find some notes and directions I had when I did mine and send them to you.
