f-12 parts tractor
maybe the hood, mine was cut around the ex pipe when someone had a straight up pipe instead of curving around hood. possible air cleaner, if i can't weld mine. maybe the bottom attachment on the steering post that holds implements on. [this is if the person that looking to but it, doesn't].
Is that the one (hood) that has the hole for the fuel system part sticking through? Not sure on what you need on the front. Need more info.
