Gents,
I am going to fix (hopefully) a small drip from unit. I have never had one apart and I am using the Blue Ribbon manual GSS-1278-A primarily for guidance. I have a seal kit from Eaton, but I only plan on replacing the small o-rings on each end. The power end (front end of tractor) I am pretty comfortable about. The control end is a different story. I am concerned about how the shaft locating balls will behave when I pull the cap. If they do fall out, are they hard to relocate back for assembly? Any tips will be appreciated.
Thanks in advance
PAddy
Thanks in advance
PAddy
