Anonymous-0
I believe I have electrical problems - I have a 12 volt conversion with a 6 volt coil and a ballast resistor- replaced one wire today and then showed about 12 volts at the connection before the resistor and 7 after the resistor. Before that change, they were showing about 10 and 5. However still not starting. I took my battery in to load test it a couple of weeks ago and they said it was ok. When I charged it last night and today - the charger showed "rev polarity"- I have it connected properly. I have no idea what this means and if it has affected the electrical system and whether or not I can still use this battery. Any help would be appreciated. Thanks.
