f12 powerlift pump
I can't remember exactly (been too long since I've done it), but I think you have to take the pump apart and remove the driven gear to get the pump off the shaft.
The pump is driven by the transmission mainshaft.
Couple more pictures that may help at the link.
Removing Trans Mainshaft
Thanks Fawteen,I was nervous about taking apart looks simple in picture. Am parting out it has seat and bracket plus umbrella holder,hope to sell. Thanks again!
There are two bolts that hold a bearing retainer on the backside of bearing that comes through the pump flange.They are small bolts.
Yea I wondered if they might come into play. So I remove them too,right? Thanks I might get this right yet!
Thanks everybody in a couple of days Ill put all your info to work. Will let you know how it turns out.
Finally after all snow and ice got the pump off, been nasty here. Your info was what I needed. Thanks! Now just need somebody to buy it!
