400 LP Spark plugs and gas hose
*IHMMJD*
Does anyone have any suggestions on what to use for spark plugs and also I need a gas hose to go from the vaporizor to the carb, case does not offer the hose.
I would suggest visiting the propane dealer or maybe a forklift
shop to try to match or update the hose. I would think the spark plugs would be the same as for the gas model 400 although specs may call for a different gap.
The hose from vaporizer to carb is low pressure or slight vaacuum and I would use silicone water heater hose available at heavy truck parts house. The hose from tank tp vaporizer is very high pressure and correct hose must be used. Off topic...I worked for years at large plant that had at least 50 LP fork lifts. Even though we had large crew of skilled pipe fitters that could handle any type pipe job out there our safety people decided we did not have anyone qualified to make up LP hoses and they had to be made up at LP dealer. I know for a fact that whoever was around at LP dealer truck driver, janitor or whoever actually made up hoses.
