Super C Grill on Ebay
MSFARMALL
Hi Fellows,
I need some help. A Super C grill is listed on Ebay; Item #220733534258. The bottom pan does not look correct to me; it looks shorter than it should. I would like to bid but it just doesn't seem correct. Would some of you guys that know take a look and see what you think?
I believe the grill on eBay is in fact for a Super C. The difference in a C and SC grill in the front is the last bar right above the seam where the crank hole is located. On a C it is not as wide as on a SC and this one looks like it has the wider lower bar. If you are good with body work (or know someone who is) this looks like a good one to recover to nice condition as the bars look really goood and not much appearence of rust outs anywhere. Hope this helps, Hal.
