Leon Torkelson
I have a International 504 utility that will start and run about 30 seconds then quit and will not start again for several hours. This happens when the tempatures are below 20 degrees. When above those temps it starts and runs fine. The points are new and gaped correctly. I have determined that it is not a fuel problem.
I was considering the Pertronex ignition, coil, plugs and wires. but at nearly $200.oo for the package is it worth it? I was reading some older posts about the solid state ignitions and John T brought up a good point about the electronic ignitions for older tractors, they are not as heavy duty as the auto systems and they will fail sooner. So what is wrong with my old system?
