curt in ky
My 966 brakes seem a little off to me. I guess this is normal but when the tractor is not running you can push the pedals all the way down and then when you start it it will push the pedals back up pretty quick. Also when it is running the brakes don't instantly respond. It's like if you barely push the pedal down, about 1-2 seconds later it will build pressure and you can feel it push the pedal back up and then it will stop you. It feels like they won't hold you back at first so most people would push the pedal down real hard and then in 1-2 seconds it will "build pressure" and they will lock up. It's real touchy. Does this sound normal or is there a problem? Thanks.
