Anonymous-0
1066 tractor, the engine oil cooler started leaking. Got LOTS of oil in the water. Any decent way to get the oil out of the radiator and the rest of the engine. It has been draining for several days, but the oil is just so thick it won't be completly drained out. When it happened on our 1566, we were able to run it with soap and water and drain it a couple times. That was in the summer though. When the temp is hovering at 0 degrees, not sure if that would work. Don't really want to put anti-freeze in it until it is cleaned out. Also no place warm to put it. Any ideas? The new cooler should be here anytime.
