cub water in oil
questadg
My dad just bought a 48 cub. I checked it and noticed water in the oil and antifreeze is leaking from the center-rear cylinder head bolt. I read the info about the cylinder head bolt and used black silicone and it still leaked. Next I used teflon tape and silicone and it still leaked. I am trying silicone water pump gasket maker now. If that does not work, could it be the head gasket? Any other suggestions?
I would pull the head and replace the gasket, use a copper coat product on the gasket (spray on). Make sure to re-torque after running a time. You can coat the bolt threads with some RTV if you would like.
Andrew
