IH 1026 Hydro problem
Andy1026
New User
Just bought a IH 1026 Hydro. Changed the hydro fluid and filters. Now the tractor won"t move forward or reverse. The steering and loader work. Hydro worked before I changed the oil/filters. Does anybody have any suggestions
From what i've read on here, you have to overfill your rear end with hytran. When you get the rear end full, then add another 5 gallon bucket. Hope this helps. Kent
Question, are you checking oil level with engine running as required on a hydrostatic tractor?
If the oil level is correct check for a leaking seal on the hydrostatic filter. It may not leak oil out but it can allow air to enter the charge pump circuit.
