100 1st and 2nd gear?
Oldiron29
Have a 100 that will not go into 1st and 2nd gear. I have pulled the cover and realign the fork and it will work a fue time than jumps out again. Should I try to bend the forks in, build up with weld or just replace them? Don't know if I can get them new. what is best fix?
thanks oldiron29
Never had that problem... but is the trans the same as a super A?... maybe some in here would know...
My uncle had a 404 with a discontinued manifold - used the same gasket as a 140... we were going to try a 140 carb & manifold but we never got the chance...
