b 450 engine sleaves
Mike Bock
i am in need of a couple of sleaves for this engine any body got any our know if a super m sleave could be machined to work they are 4in. by 10 in long with a .190 lip on top and are 4.250 to block
This maybe of no help but I was looking for something the other day and
Bowden Engine Parts in NZ has lots of stuff but can't remember if any were for B450.
I would give that webers tractor works a call first but the best I can remember thin wall sleeves from a MD not SMD will slip right in. A MD came out with a 3 7/8 bore but you could buy thin wall sleeves and increase the bore to 4" I looked up part numbers a few min ago after reading this, the MD and SMD break down the sleeve assy set and gives numbers for pistons ,pins , sleeves but the B450 parts book does not break it down. Just list part number for complete sleeve assy. I went thru this over 30 years ago with my B450. Used parts for these old tractors are very hard to find in my aera. I don't think that I have not seen a MD or 450 in salvage yards sence the early 1990's. I don't live to far from sikeston mo.where there are three good size salvage yards there.
I am having custom sleeves made for My SMTA Diesel right now by Advanced Sleeve. The are only $138 each which was cheaper than factory sleeves that would not work in my block. I would give them a call if you can take some accurate measurements of what you need.
