Need Photo of Farmall A with No. 16 Mower
Anonymous-0
Hello. I have a 1945 Farmall A and a No. 16 Mower. I have a pneumatic lift on the tractor but need to see how it hooks up to my mower. Anyone having any photos please send them my way. I would really appreciate it. THANKS
Not very good, but only one I have. It is a bear to get on
After re-reading sounds like you want a pic of a
A-21, which has the extended rochshaft for the long rod to attach to and go up to the Touch Control arm. I have one mounted, but no pic.
I have a No.16 mower on my 46A and a Pneumatic lift-all. My grandpa just ran a piece of cable down from one of the lift arms to the mower looped it around around and put a cable clamp on the cable. Sorry I don't have a pic. I have a Harvester mower parts book but it doesn't show anything for use with a lift-all. I would like to see a good setup.
Hello and THANKS for the picture. Yep, just like the one that I have except my tractor does not have the lift arms on it. Know it will fit my A but wanted to see if anyone had one that is hooked up to a Pnuematic lift. Can see how it would be a bear to get on. Have to take the drawbar off get all lined up. Think it will be nice to get restored and put on the tractor for the show. Who knwo might even try to cut some hay with it. Oh, any idea if you still can get the grass board and rod? THANKS
Yours is mounted on a SA and the A doesent have lift arms nor a rockshaft two comepletely different set-ups the SA us hy and the A is pneumatic from the exhaust system. Correct owners manual will fix the problems.
