(quoted from post at 08:51:42 12/16/10) Always + to +, - to -. Possiblility that battery will blow up. Best to connect to directly to starter and a ground away from battery. Lots of opinions on this in the archives.
(quoted from post at 11:46:21 12/16/10) Why would you tell anyone to use a 12 to jump a 6 you can do it all you want but telling someone else to do it is not good.
(quoted from post at 12:44:07 12/16/10) YES if the tractor [b:f249082cd1]youre starting is a Neg ground[/b:f249082cd1].....
YES the starter will spin
YES it will stop spinning when you remove the cable
Actually Id say hook the last ground to a clean frame/chassis member YES away from the battery butttttttttttt also close to the starter is a good thing
YOU GET AN A FOR LISTENING
John T
(quoted from post at 15:53:13 12/16/10) Just one more reason to convert to 12 volt negative ground.
(quoted from post at 19:20:09 12/16/10) If it was dead yesterday, and you need it today, why didn't you charge it? A good 6V battery will start an M with clean connections and proper cables. I bought a 6 volt SM last summer that I intend to leave that way.
(quoted from post at 08:45:59 12/16/10) This is probably a stupid question, but I've never had to jump start a 6v tractor before. How do you hook the cables up? Do you hook them up as you would with a 12v (+ to + and - to -) even though the tractor is positive ground??
(quoted from post at 08:18:58 12/17/10) Sounds like you have other issues at work here. Acts about like a diesel. I'd put a circulating heater in it and plug it in every night. Might also have the starter check to see if it is dragging.
(quoted from post at 11:10:06 12/17/10) There are plenty of threads and posts on that in the archives including just a few days ago. Do a search on heaters. That said, there are circulating ones for the radiator hose and a heater hose if you have one. Block heaters for the block soft plug. Magnetic heaters for the oil pan which are removable. Haven't heard of a drain plug heater except the type in stock tank waterers. Circulating heater can warm it up in an hour and the others take up to 6 hours and still never warm the water and block all over.
Sounds like you need to use your tractor every day in cold weather. 12v conversion may help a little but there are a lot of us who have to jump start the 12v systems in cold weather which doesn't solve your problem.
Best thing for the engine in the long run would be to keep it warm all the time so it doesn't go through the freeze/warmup cycle all the time and worry about oil not properly circulating until it warms up. It will provide some residual heat to the intake manifold and your hydraulic supply as well. If your hydraulics are still too slow you can put a magnetic heater on that supply as well but mine quits whining after a few minutes when it warms up. Let us know what you do.
(quoted from post at 18:38:21 12/17/10) Why would you need to disconnect the ground cable? If you are boosting the starter the 12 volts can't get to the 6 volt battery unless you use the starter switch. How would it start with a dist instead of a mag if you took off the ground cable??
(quoted from post at 08:57:32 12/19/10) What provides the juice to the coil when cranking with the ground cable off? Something doesn't sound right here. A generator has to spin faster than cranking speed to feed the coil.
