JDMorris #1 - keep in mind that when you are actually cranking, system voltage can drop to 9 volts - and some coils don't work at 9 volts. The instant you stop cranking - voltage spikes up to 12 volts and it fires. This is why it is best to have a 6 volt coil in a 12 volt system. Most do. 90% of all cars and trucks that came new with 12 volt systems use 6 volt coils. Same goes for many tractors.
Just when I thought I had all the 6v -12v possibilities covered in my mind JDMorris throws this at me.
So what you are saying is that it's better to KEEP the 6v coil when converting to 12v battery.
Change the VR and Battery and keep the 6v coil.
Thanks,(I think)
Dell
