Broken hub on # 15 plow
Anonymous-0
I have a broken hub on what I believe is #15 IH Plow. The casting number that is on the hub is 651808-R3 and when I called the I H dealer he indicated that it has been replaced by number 47220-R2 at the tune of $186.00. They say it is a common hub for different IH implements.
Just wondering if any one had a hub from an old junk plow or anything else that you wanted to sell. The hub is about 6 inches in dia. and has a 4 bolt pattern. inside of the hub are two bearings, one for inside and one for outside. Any help on this would be appreciated.
That's pretty much a standard 4-bolt implement hub. I think most brands of stuff with 4-bolt wheels used them.
You should be able to find a replacement hub at any implement salvage yard, sold by the pound.
