IH International Harvester PTO Driven Hydraulic Pump
sysgenss
New User
I believe that this Item might be a International Harvester PTO Driven Hydraulic Pump. Can someone confirm this. Also if anyone knows what Tractor Models that it will work on.
Markings:
Main Casting:
"H" over an "I".
Front Side: "362246" & either "B1" or "R1".
Back Side: "362247" & either "B1" or "R1".
Pump Casting:
"H17 A54".
"05-318".
Any help would be much appreciated.
(quoted from post at 02:39:02 12/09/10) I believe that this Item might be a International Harvester PTO Driven Hydraulic Pump. Can someone confirm this. Also if anyone knows what Tractor Models that it will work on.
Markings:
Main Casting:
"H" over an "I".
Pump Casting:
"H17 A54".
"05-318".
That is called a hydra creeper attachment for some offset IH tractors, 140 ETC.. Drove the tractor with hydraulics from the PTO shaft for special speed needs.
whats the other side look like , I have a cover like that but mine has Hydra-creeper cast on it above the center pin
The 362246 R1 & 362247 R11 show in my Super A parts book as part numbers for the front and rear covers for the Hydro creeper accessory just as the others said below, so it also fits the Super A.
Do you want to sell it, I've been kinda keeping an eye out for one, also do you have any of the linkage that goes on the PTO handle?
It's a rare attachment and has significant value. Put it on eBay and watch'em go nutz. You are missing a few parts such as torque bracket and by-pass block that attaches between the hydraulic manifold and Hydra-Touch. That block is available new at around $40.
Thanks for the info much appreciated.
I'm actually researching this piece for a Neighbour. He has asked me to sell it for him on eBay. I can advise you once it is listed. Regards,
Russ
