farmall tach drive distributor?
Wardner
IH began with tachs in 1955. Any four cylinder IH engine from that date until 1958 that has the tach drive hole and 2-screw cover can use any of the three tach drives. IH Gas or Diesel use the same drive. They are interchangeable. Later models of the Cub and 140 also use the same drive.
You need a gas tach. The Diesels rotate backwards. You want a 0-2400 IH tach with the "0" on the left hand side. They will all work but the road speed numbers will be slightly off. The 540 RPM line will vary also.
Tachs are being reproduced and they are a quality item. You can find them new on eBay between $60 and $130.
I don't believe there is a source for new tach drives. Used drives (usually as part of the distributer drive) can be had on eBay for around $50-$100. You take your chances on a used drive. The gear is plastic and may be stripped. eBay buyer protection plan will refund your cost if the drive is no good.
Sorry, I can't tell my right from my left. The "0" will be on the right side and the needle will turn clockwise. Counter-clockwise on diesels.
I just noticed that you have a Power Unit. I am fairly sure that they used the Stewart-Warner tach but they may have a full face dial. S-W was also the mfg of the tractor tachs.
S-W tachs come in two ratios. One is twice the speed of the other. If you are going to use a full face tach, you will need the high speed tach. Both ratios are available for the full face tach. I believe the low speed tach was used on 2-cycle Detroit Diesels where the tach drive came off the cam or balance shaft. Are you confused yet? I think I am. Just get a tractor tach and you will be all set.
Why not use an electronic tach?
