Need a wiring diagram for a 140
OB OBrien
Need a wiring diagram for a Farmall 140. It's a 1956 with a 12 volt conversion and a voltage regulator. Have found some wires disconnected and don't know where they go. One of the wires goes to the "L" connection point on the voltage regulator. I think the other end goes to somewhere on the light switch, but am not sure. Also cannot keep a charge on the battery, even when everything is turned off. ?? Would appreciate any help.
Thanks OB
