farmall m air filter oil grade
Wally, I believe the operator's manual states to use the same weight as you are using in the engine. Unless you use something lighter in the winter I believe the manual calls for SAE 30 weight for above +32 F but a lot of folks use the present day multi-grade detergent oils instead of the straight weight non-detergent ones noted in the manual back when that was the only oils available. Hope this helps, Hal.
