rear steel hydraulic lines on farmalls
jcwag
just wonering if anyone knows a good way to replace the rear hydraulic lines on the farmall 300-350-400-450 series that run alond the right side of the battery box. my brother did one 15 yrs ago or so, he cut out the bad spot and took the same size line to fill in then took the next size bigger and slipped it over the top of the joint and braized it closed, but it dosnt look quite correct. any ideas??
Hoses from the under-tank ports to the rear work if you want functional.
If you want original and correct-looking, you need to get the tubing and bend up new lines on a tubing bender, TIG weld the correct fittings on each end, paint, and install them.
