'48 C leaking rear end oil
Clint Proeschel
06-20-2000 17:37:07
HELP!!!!! !! My C farmall is leaking oil out of the rear end! is is coming from just above the PTO shaft, where the belt pulley mounts, I think it mounts there anyway. I tightend the 2 bolts up, but to no avail! It is also leaking out the axle housing at the end on the left hand side(as looking at it from behind). Any help is greatly appreciated!!
Milan D. Radakovic
06-21-2000 15:59:36
 Re: '48 C leaking rear end oil in reply to Clint Proeschel, 06-20-2000 17:37:07
The leak at the belt pulley is an easy fix.. Drain the oil out from the pulley/pto housing. There's a plug at the bottom of the housing. remove the bolts that hold the side cover where the belt mounts, and take the covber off, clean it and permatex the cover, and put it back together.
The axle leak, you'll have to remove the wheel, then remove the cap at the end of the axle housing (the part with the grease fitting), inside there's a grease seal, which you'll have to replace with a new one.
