For PAKEHA, F12 clutch/throwout pics
36F30
I know you asked for these, I just pulled this one apart, 9" clutch on a 36 F12 same as a F14.
Flywheel
Clutch disc
pressure plate
Throwout bearing
Thanks for these. Much appreciated indeed. Seems that mine is set up the same, yet I still have about 3/4" clearance between the thrust bearing and the fingers and no adjustment possible. This just means a long push on the clutch pedal before it engages.
Thanks again,
kind regards
Adrian Whiteman
