sickle mower IHC drawbar style mounted in place of drawbar
My son has an H with a drawbar mounted sickle mover. The one way cylinder on the left side ahead of the axle housing that raises the mower has blown its seals. Are there any parts available for those cylinders? Are there any cylinders around?
it is very likly a standard liftall cylinder it is described as being about a foot long at the cylinder with 3 or 4 tie bolts holding the ends on. It has a sleeve sticking out one end with the push rod inside it, and a mount hole on the hydraulic connection end. They should be easily repaired with leather cups and seals from several sources, including NAPA and hydraulic shops. caseIH is also likely to ghave the parts.
They are also very easy to find used. Jim
