3 point hitch capacity
The issue you'll most likely run into is keeping the front tires on the ground. I went to pick up a new plow with my SMTA before I had the front weights on. When I lifted the 3 point, the front end lifted instead. Took about 400# of counter weight to keep er down.
Ben
Probably 90% of tractor wt. But being safe means that the steering wheels need at least 20% of the weight to steer reliably, and then only for off road use, or low speeds (10mph or less).
A 45foot trailer is OK if it is ballanced on axle location to put solid but managable toung Wt. on the tow vehicle. Brakes are another factor of usability. Two rear wheels with modest load on them do not stop, in a controlable manor, a 30 ton load. Jim
