H 2 way hydraulic valve control rod... same part on a M?
I'm trying to track down all the parts I need to add the original accessory 2 way hydro valve setup to my H. I've got just about everything except for the control rod that you push/pull on and the longer jointed dipstick. Are these parts the same on a H and a M? I found a guy parting out a SM that has the parts I need, I just want to verify that they'll fit my H
My parts book shows the H rod as part number 353115 R2 and the dipstick is 353120 R91.
Thanks!
Paul
I can't say for sure, but my educated guess is that they are not the same. An M's would be longer.
It's pretty easy to fabricate your own rods. I made the hydraulic control rods for my Super H. They're just 3/8" mild steel round bar. All you need is a bench vise to make the bends and a torch to heat the bar.
yeah I figured if I didn't have much luck finding an original one I'd just borrow the one off a friends H and copy it the best I can.
I borrowed one off of my M once to use on an H I sold. It fit, but seems like the rod stuck out more than it did on the M. Was probalbly only a couple of inches, and that could have just been the differences in the 2 tractors.
