BohemianJon
New User
Not sure what"s going on, but my 2 month old 6 volt battery seems to be always low or run down and barely starts the tractor. Sometimes I have to crank it. My battery + goes to the frame and the - to the starter...wire from generator to same pole on the starter. I"ve been told this is the way it should be. When I bought the tractor, none of the wires or battery were installed. Is this the right hook up? Could it be that the tractor was converted to a 12 volt system...how can I tell? I sometimes have a metal impliement mounted to the tractor setting on the grownd...would this drain the battery? Any suggestions and recommendations will be appreciated. Thanks
