what is the proper hydraulic oil for a super H
holmesw
Hi, I was wondering if anyone could tell me what type of hydraulic oil is the righ oil for a Super H? More speciffically what is the proper viscosity? I do not want to put the wrong stuff in and do any damage. If any body can give me any information, I would appreciate it. I do not know the kind of pump.
for the super h it dont matter one bit. you can use hy-tran if you want or just the ordinary hyd.oil.summer #68 vis. winter #32 vis. and if its real cold you can go to #22 vis.just remember the cam gear that runs the pump is prone to failure in cold winter conditions. i have seen a few with the keyway torn out on cam.hy-tran is good to if your using the cyl. on diff. applications not to contaminate other units.
If the pump is in front of the distributer and the reservoir is under the gas tank, Hytran or equivalent. Otherwise SAE 30 is ok as long as you are not sharing implements with another tractor.
