N.O.S. Delco-Remy Cutout for Farmall A generator
hayrake25
Hello. Do you all know of any vendor that sells N.O.S. Delco-Remy cutout or good reproductions. Please let me know what you all use. Thanks this is for a 1945 Farmall A.
The cut out relays for the Delco on a John Deere are available aftermarket, but those do not have the same appearance as what Farmall used, and I don't know if they would interchange and function the same. Most folks just convert the cut-out system over to a voltage regulator.
