Farmall 230 hydraulics
Recently have been crossing to the dark side and have purchased a 230 with the touch control hyd. fasthitch. The rear end oil is very milky and needs to be changed. I was also told that the hyds feed off the trans fluid? What is the best method of flushing the hyd.
Thanks
Frank
(quoted from post at 19:56:16 09/10/10) Recently have been crossing to the dark side and have purchased a 230 with the touch control hyd. fasthitch. The rear end oil is very milky and needs to be changed. I was also told that the hyds feed off the trans fluid? What is the best method of flushing the hyd.
Thanks
Frank
The hydraulic system is seperate from transmission oil. The hydraulic system reservoir is in the torque tube.
