Hi guys.
The HLRN shifter on my 706D is firmly stuck between Neutral and Low. It was working fine and then locked up when going from reverse to low. Moving the tractor a few feet back or forward doesnt help. Doesnt matter whether the tractor is running or shut off.
The external linkages are working properly, no binding or interference. The problem appears to be in the case. I have the floor plate off. Any thoughts or advice before I pull the cover? Things to watch out for? Care to hazard a guess as to what is wrong?
